Anyone know if the neutral light is suppose to work with the MC28 / HRC Card wire splice?
After doing the splice, it fires up, turn signals, headlights and horn work but no neutral light. Neutral light definitely works as I have a connector that will allow me to do and undo the splice.
Nope, mine doesn't work either, I bought it spliced but from looking at the wiresplice section the fact the neutral, oil and sidestand wires are al supposed to be grounded is probably going to mean the respective warning indicators are all gone. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Yep, thought I'd cycle through a few of the funny one liners I heard over the weekend, Stephen's "we like people who jet smaller, it shows balls" in response to Jeff's list of mods before his dyno run which was "HRC pipes, modded airbox, smaller jets " is probably next. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I run the HRC loom and card and it doesn't show a neutral. Took me such a long time to find neutral last time I used it I've given up. Just park it in gear and hope I remember to pull in the (new) clutch whenever I crank it up.
I had wirelss splice to match HRC card, but the side stand light is still working, also when i riding on, I felt uncomfortable with, becasue the speed can not up. main jet is 150, cab is open(no air clean box), with HRC 030 card, what can do for the best set up, did I do something wrong? _________________ 1996 HONDA RS250
