MC 21 Engine sputters when put in gear
ponsone1
Fri Nov 23, 2012 4:18 pm » Post: #1 » Download Post
I have an MC 21 that when at idol runs great, but as soon as I put in in gear it start to sputter and will not run.
I am fairly confident it is not the kick stand switch.
I am thinking it is the neutral switch. It lights up green when in neutral and goes off when placed in gear, but sputters immediately.
Maybe linked to the gear switch indicator.
I could use some expertise on this one.
Thanks
Fri Nov 23, 2012 6:27 pm » Post: #2 » Download Post
Disconnect the gear position sensor and try it.
Has the bike been de-restricted. A de-restricted MC21 can run without the gear position sensor connected at all so will prove a point/fault.
nxrsr20
Fri Nov 23, 2012 7:35 pm » Post: #3 » Download Post
Silly question time:
Is the TPS connected and giving a good signal?
Your coils and leads are ok?
Battery is good?
ponsone1
Gear position sensor
Fri Nov 23, 2012 8:36 pm » Post: #4 » Download Post
I disconnected the gear sensor and it does the same thing.
StephenRC45 wrote:Disconnect the gear position sensor and try it.
Fri Nov 23, 2012 8:44 pm » Post: #5 » Download Post
Well you know its nothing to do with the GPS/Neutral switch then.
Dirtdigger818
Mon Nov 26, 2012 4:43 pm » Post: #6 » Download Post
is the battery fully charged ?
noidea
Tue Dec 11, 2012 10:29 am » Post: #7 » Download Post
sounds fuel related.
TuckerBag
Tue Dec 11, 2012 8:49 pm » Post: #8 » Download Post
Sorry for going super simple on this, but it has to be asked.
Perhaps the clutch adjustment is such that it is not fully disengaging when the clutch lever is pulled in?
Just had to get that one out of the way Smile
Dannyvirk
Wed Dec 12, 2012 12:30 am » Post: #9 » Download Post
Heya
I love these games, first question i'd ask is does it splutter on both cylinders or just one?
If you can work that out, it might narrow down the posibilitys.
noidea
Sun Dec 16, 2012 7:35 am » Post: #10 » Download Post
No more clues??
