As some of you know I own a carbon fibre company, as a project and technical demonstrator we are thinking of producing a full carbon ceramic exhaust system. We are starting with a two stroke system as the design is slightly easier, we have sourced and tested a resin system that is good for 1800 degrees C sot that's pretty much covered.
We are using my Jolly Motos as a template but what I can't find is the internal structure of the expansion chambers. I don't want cut open my jolly motos so need to know whether there is any internal baffles or structures internally so we can replicate them exactly.
Has anyone either got pictures or diagram of,the internal or just the info that there is nothing inside?
Things to bear in mind are RC Valves vary the ports and it depends on where you want the power & where you plan to ride. You could end up with great track pipes that are no fun on the road _________________ Why do things simply when you can complicate them
Not sure of the practical applications but should be cool as fook. We are using it as a technical piece looking into using carbon and ceramics in high temperature applications.
Perhaps you should be looking into Solid Oxide Fuel Cells - they operate at temps upwards of 800C, and are in need of a breakthough for heat cycles, since the ceramic coatings can only cope with a few hundred at best.
