Exhaust project
carbonpaul
Exhaust project
Mon Apr 29, 2013 2:27 pm » Post: #1 » Download Post
As some of you know I own a carbon fibre company, as a project and technical demonstrator we are thinking of producing a full carbon ceramic exhaust system. We are starting with a two stroke system as the design is slightly easier, we have sourced and tested a resin system that is good for 1800 degrees C sot that's pretty much covered.
We are using my Jolly Motos as a template but what I can't find is the internal structure of the expansion chambers. I don't want cut open my jolly motos so need to know whether there is any internal baffles or structures internally so we can replicate them exactly.
Has anyone either got pictures or diagram of,the internal or just the info that there is nothing inside?
Mon Apr 29, 2013 3:19 pm » Post: #2 » Download Post
I don't think there's anything inside an after market expansion. OEM ones are double skin, which is why they are heavier
I googled this, but you'll need a lot of technical input http://www.mh-aerotools.de/airfoils/javapipe_en.htm
Things to bear in mind are RC Valves vary the ports and it depends on where you want the power & where you plan to ride. You could end up with great track pipes that are no fun on the road
carbonpaul
Mon Apr 29, 2013 3:22 pm » Post: #3 » Download Post
Thanks for the link and info. I intended to use the jolly Motos design as these seem to be a good pipe to start with
Mon Apr 29, 2013 3:28 pm » Post: #4 » Download Post
I found this book as well
http://www.amazon.co.uk/Two-stroke-Performance-Tuning-Graham-Bell/dp/1859606199/ref=sr_1_1?s=books&ie=UTF8&qid=1367249286&sr=1-1&keywords=Two-stroke+Performance+Tuning
Alzazorq
Tue Apr 30, 2013 7:12 am » Post: #5 » Download Post
This is going to be interesting ! Shocked
Tue Apr 30, 2013 2:42 pm » Post: #6 » Download Post
Will Silikesguiness delay his project for this? Laughing
Tue Apr 30, 2013 3:27 pm » Post: #7 » Download Post
that bloody thing is delayed enough ROTFLMAO
cgallant
2001 Honda RS250
Tue Apr 30, 2013 4:21 pm » Post: #8 » Download Post
RobH wrote:Will Silikesguiness delay his project for this? Laughing
A government agency could have built a motorcycle quicker then that project is taking!
Charles Gallant
Tue Apr 30, 2013 4:31 pm » Post: #9 » Download Post
Laughing
carbonpaul
Tue Apr 30, 2013 4:58 pm » Post: #10 » Download Post
Not sure of the practical applications but should be cool as fook. We are using it as a technical piece looking into using carbon and ceramics in high temperature applications.
Fri May 03, 2013 9:09 pm » Post: #11 » Download Post
Have you got a projected weight?
Perhaps you should be looking into Solid Oxide Fuel Cells - they operate at temps upwards of 800C, and are in need of a breakthough for heat cycles, since the ceramic coatings can only cope with a few hundred at best.
mighty max
Sat May 04, 2013 2:41 am » Post: #12 » Download Post
Carbon body frame cover....
