Woodruffkey for rs coils
crx_rex
Mon Jul 22, 2013 7:44 am » Post: #1 » Download Post
HI!
What kind of Woodruffkey do I need to get the right timing with rs250 coils on my MC21?
1,2,3 or 4 degrees retarded or forwarded?
Thanks!
Honda for Life
Mon Jul 22, 2013 8:13 am » Post: #2 » Download Post
Changing the ignition coils do not alter the ignition timing.
crx_rex
Mon Jul 22, 2013 8:17 am » Post: #3 » Download Post
Okey, somewhere I read that the timing needed adjustment with stronger coils and spark. Guess that it was bullshit.
When do one need to change the timing? Different fuel?
Honda for Life
Mon Jul 22, 2013 8:23 am » Post: #4 » Download Post
You may be able to get some gains playing with the ignition timing with better coils but which way will depend on the fuel used and the state of the engine.
I wouldn't for arguments sake say, just because you have RS coils you need 1deg advance for example.
crx_rex
Mon Jul 22, 2013 8:50 am » Post: #5 » Download Post
Okey,
Well exept for the rs coil I have full race exhaustsystem, HRC jetting, HRC ignitionbox, open airbox with some HRC filter, short plugs
A combination of "R" cylinders with "SP" rear heads for some increase in compression.
On top of this I do not know how the increase of ethanol in the pumpfuels affect the performance and reliability of the bike.
Does this combination make any difference for the sake of ignition timing?
Mon Jul 22, 2013 9:39 am » Post: #6 » Download Post
Best thing to do would be get it down to a dyno and get some base settings to work from.
crx_rex
Mon Jul 22, 2013 9:57 am » Post: #7 » Download Post
Okey, thanks for the help, Stephen!
