I run TYGA fairings, so ive removed the std fairing mounts. Had to remove the 2t tank resivoir mount as well and make my own (see next pic). I used one of the factory nutserts, and added 3 of my own.
Its hard to see, but there is a bracket that mounts using the same bolt that bracket on the upper cross bar mounts with (that holds a couple plugs and the servo/valve thingos) and holds the inner resivoir up and in position.
This is what it looks like with the coils mounted. Had to make my own leads from 8.8mm lead to suit. Also used deutch plugs to connect to the loom (very pretty but not in picture). Outer 2t resivoir uses the new upper coil mount (about 10mm higher than the normal mount)
Part i used was MSD # 8230
http://www.msdignition.com/Products/Coils/Stock_Replacement/8230_-_Single_Tower,_Isolated_Ground_Coil.aspx
