Click on the parts list on the left had side of the page and select RS250 then scroll down until you see F5 front fork. This will give you a break down of all the fork components. I could be wrong (hopefully!), but I think one or both of those bushes are discontinued.
I did want to add that modern 41mm forks use the same dust/oil seals as this fork if anyone care. For example, a 05 cbr600r uses the same seals. No point in buying super overpriced rs250 oem part numbers. You can buy all 4 seals for the price of 1 oem rs250 seal.
