nx5 USD fork bushings
kan3
Mon Jan 13, 2014 3:45 pm » Post: #1 » Download Post
Hi,
I have some early 90s nx5 USD forks and was curious if anyone had the part numbers for the bushings?
sennidott
Mon Jan 13, 2014 4:26 pm » Post: #2 » Download Post
51414_NF5_611 BUSH. guide
51414_NX5_701 BUSH. guide
Have a look here: http://tsrworldwide.com/
Click on the parts list on the left had side of the page and select RS250 then scroll down until you see F5 front fork. This will give you a break down of all the fork components. I could be wrong (hopefully!), but I think one or both of those bushes are discontinued.
kan3
Sat Jan 18, 2014 3:15 am » Post: #3 » Download Post
thanks a ton
I did want to add that modern 41mm forks use the same dust/oil seals as this fork if anyone care. For example, a 05 cbr600r uses the same seals. No point in buying super overpriced rs250 oem part numbers. You can buy all 4 seals for the price of 1 oem rs250 seal.
kan3
Sun Mar 23, 2014 3:45 am » Post: #4 » Download Post
Got the forks back together and thought I'd update on what I used:
I'm in the US so these were easy to get for me
OEM Showa dust seal and oil seal set(need 2) - 51490-MEE-D01 - $14 US
OEM Showa upper bushing(need 2) - 51414-KCR-003 - $7.50 US
Racetech lower bushing(sold as a pair) - FMBO 41202 - $20 US
