Best way to clean up barrels
das134
Fri Jan 17, 2014 11:30 am » Post: #1 » Download Post
Hi everyone, I have searched all over but as far as I can see there isn't a thread on this topic...
I have a couple of spare barrels lyiong around from an old seized engine. I'd like to get them cleaned up to see if they will be usable again.
There is piston material scraped on to the inner surface, what is the best way to clean this off? Can it be cleaned off without causing damage?
I also have some heads with detonation and another that has had a bit of ring or something leave a couple of dents. At what level do these become unusable or at least 'you should really just get new ones'?
Cheers for the help.
Fri Jan 17, 2014 3:08 pm » Post: #2 » Download Post
I think the stuff you need is called muriatic acid, somebody will correct me if i'm wrong, sounds like muriatic anyway, if its not too bad I have cleaned them up before with a very fine wet and dry and some oil, something about 1200 grade, round and round, not up and down.
Neal
Fri Jan 17, 2014 10:15 pm » Post: #3 » Download Post
We call it swimming pool acid , get an earbud and apply it to the ally smears and watch it bubble away . Rinse off well and repeat if necessary .
das134
Sat Jan 18, 2014 9:40 am » Post: #4 » Download Post
Neal wrote:We call it swimming pool acid , get an earbud and apply it to the ally smears and watch it bubble away . Rinse off well and repeat if necessary .
Ahh awesome. Do you know where something like that would be sold?
Reckon I could potentially bring 2 barrels back to life...
mtec666
Sat Jan 18, 2014 10:17 pm » Post: #5 » Download Post
Once you have cleaned with acid make sure you run a bottle brush hone through the cylinder with something like wd40 or get your local bike shop to do it.
Neal
Sat Jan 18, 2014 11:08 pm » Post: #6 » Download Post
Should be some at any hardware store , thing is the 5L bottles are more than you need , unless talk nicely to a pool cleaner guy .
