Injector pump oil lines
drunkn munky
Fri Feb 07, 2014 11:46 pm » Post: #1 » Download Post
Mine have become brittle and broken along with the vent lines, david silvers dont have these in stock is there generic type hose i can use?
Hobbit210
Oil lines
Sun Feb 09, 2014 11:12 am » Post: #2 » Download Post
If you mean the pipes from the pump to the carbs then you can use any plastic or rubber type oil piping. I went for the clear type.
I often use my local bike spares shop http://www.ridersmotorcycles.co.uk/Scripts/default.asp.
The chap that runs it used to import NEW Jap bikes and has a wide knowledge of most things Jap 2 stroke.
Hope this helps.
Mike
gepe
Sat Feb 15, 2014 9:51 am » Post: #3 » Download Post
The magic word is bulk tube.
I think this is what you are looking for:
95005-3000150M
It's one meter and costs around 9 Euros. Inner diameter is 3 mm, outer around 6.5 mm (the correct clip is the B6.5 type).
You need two pieces, 140 and 160 mm.
Most of the air tube is 95005-5500120M (inner dia 5.3 mm) except for one 30 mm piece which should be from 95005-3500120M.
lamfactor
Sat Mar 08, 2014 3:41 pm » Post: #4 » Download Post
I agree, Clear Tubing is the way to go
Being able to see the injector oil in the tube is so comforting and a piece of mind!
I have seen clear air tubing and also the clear tubing used for automotive window washer fluid routed to the spray nozzles on the bonnet.
