Removing flywheel without damaging crank
das134
Sun Apr 06, 2014 6:34 pm » Post: #1 » Download Post
Hi guys,
I'm looking to remove and replace the flywheel on my engine, but I am a little bit hesitant to do so as I want to ensure the crank stays true.
The tech section says to lock the rods to jam the crank so that the bolt can be loosened/removed. Is this ok for the crank? It worked well on my broken engine, but I wasn't worried about the crank for that one....
Cheers for any help.
nobby62
Sun Apr 06, 2014 6:40 pm » Post: #2 » Download Post
I used that technique when stripping and rebuilding my engine.... had no problems... all I would say is be gentle with the torque wrench, no jerking, just a gentle increase in pressure until you achieve the required torque.
Sun Apr 06, 2014 7:48 pm » Post: #3 » Download Post
Have a look at the bottom of this page.
http://tech.nsr-world.com/nsr250/mc21/mc21-crank-specifications.php
Genuine Honda flywheel pullers for the NSR can be purchased though the marketplace if you required one.
das134
Mon Apr 07, 2014 7:50 am » Post: #4 » Download Post
StephenRC45 wrote:Have a look at the bottom of this page.
Cheers Stephen,
I actually have the flywheel puller, which is very effective. I was more referring to the initial loosening of the main bolt. It seems that this puts a lot of pressure on the crank, and I was wondering if the potential of damage could be removed/lessened.
Is a flywheel holder the solution?
gepe
Tue Apr 08, 2014 2:30 pm » Post: #5 » Download Post
You can do it without a flywheel holder and you might not effect your crank's truing.
can, might, should ... you never know.
To be on the safe side, use a metal bar with 2 screws through it as flywheel holder. There is a different thread where we did some torque/load calculations.
And: it's not only the crank that MIGHT suffer, also the conrod small ends MIGHT suffer from the pointy load.
There is a reason why Honda uses a flywheel holder and the tool which blocks the gear on the RHS to remove that nut.
das134
Thu Apr 10, 2014 10:35 pm » Post: #6 » Download Post
gepe wrote:You can do it without a flywheel holder and you might not effect your crank's truing.
Thanks for the advice. A flywheel holder will be easy to make so will do that. What about the gear holder your're referring to, what does that look like?
