MC28 Suspension setup question
Phatmc28
Fri Feb 04, 2005 9:59 am » Post: #1 » Download Post
A) what is the standard suspension setting for a mc28sp
B)the hrc preload on the front says 12mm from top ring to bottom face my question is the top ring. is that the 1st full ring or the half ring above it where the spanner slots are
thanks
Fri Feb 04, 2005 11:21 am » Post: #2 » Download Post
This may be a dumb question, but why do you want the standard settings?
Jezza
Sat Feb 05, 2005 12:00 am » Post: #3 » Download Post
This may be of some assistance to you: http://www.nsr-world.com/tuning/250-tuning/suspension/
Jerry Lai
NSR250 [MC21SP]
Sat Feb 05, 2005 1:15 am » Post: #4 » Download Post
Don't forget that the HRC settings will be geared towards the average Japanese ride, someone likely to be about 150cm tall, weighing just 50-60kg!
Not that I am saying you are likely to be a portly Westerner (such as myself), but don't expect the HRC settings to work miricals for you. There is no substitute for a re-valve based upon your own weight and riding style.
Thu Feb 10, 2005 10:23 am » Post: #5 » Download Post
The MC28 in stock form is a bit wobbly round the track. Needs beefing up.
I used 0.95kg springs at the sharp end and a 13kg spring at the back.
For fork oil I used Castrol 10W set at between 145mm (HRC setting) and 135mm. The latter setting was good for me.
The rear shock was ok, but could have done with some internal changes whcih we weren't allowed to do. The twiddlers were pretty much all the way in, which isn't really the answer, but sufficed.
I'll send Andy the F3 shimming data for the rear shock so that he can put it on the site. works pretty well in savage conditions, but may be a little harsh on the street.
nsrmonkey
Thu Feb 10, 2005 1:17 pm » Post: #6 » Download Post
[quote="Matt@TYGA"]I used 0.95kg springs at the sharp end and a 13kg spring at the back.
quote]
how did you get the spring off the shock?
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Thu Feb 10, 2005 2:06 pm » Post: #7 » Download Post
Bloody hell Monkey...
Get that shock/spring in a box and send it down here! We'll swap it for you!! :)
nsrmonkey
Thu Feb 10, 2005 3:09 pm » Post: #8 » Download Post
Shocked Embarassed
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
ericandchi
springs
Thu Oct 23, 2014 1:31 am » Post: #9 » Download Post
I decided to open an old thread. I'm 185 lbs....so need a heavier spring on the rear. Does anyone have recommendations on spring size and a source.
