Swinging arm, am I missing a spacer or a brain cell?
Sly Fox
Sat Jan 31, 2015 4:11 pm » Post: #1 » Download Post
What's going on here??
MC21 swing arm assembled does not look right to me, (this is how I bought it).
The spindle looks like it pokes out to far and the locking nut is hanging on by about two threads:
This is my first NSR but I have had a few Hondas and it look squiffy to me, what do you think?
Here are the left and right sides of the arm between the frame so you can spot any missing bits:
(I have looked at the parts page and couldn't see anything…..I'd look in my dodgy manual but I sent it back Rolling Eyes )
Sat Jan 31, 2015 6:57 pm » Post: #2 » Download Post
It looks to me like you could be missing part# 10, or you may have fitted #9 and #10 on the wrong sides.
Usually, the adjuster (part# 11) just pokes out from the inside edge of the frame spar, and the castellated lock-nut screws on a good way. There should indeed be about 5mm or so less thread showing on the outside of the pivot bolt.
Sat Jan 31, 2015 7:16 pm » Post: #3 » Download Post
Here's one fitted correctly, so compare yours to.
Sorry about the shonky photos! Taken with the creation of the Devil, the phone camera!
Sly Fox
Sat Jan 31, 2015 7:41 pm » Post: #4 » Download Post
ooooohhhh yyyeeeaaahhhh, I see it now! Very Happy
My insert in the bearing is flush with the swinging arm, (chain side) when it should stick out in a top hat style.
I think I'll turn something up and pop it in…..or find two washers!!!!
(I could buy a Honda part but that can wait for the 2016 restoration)
Thank you!!!!
Sat Jan 31, 2015 7:54 pm » Post: #5 » Download Post
You will see one "top-hat" is longer than the other... if you have them both fitted (hard to see from the photo), then I expect they are in the wrong sides.
There should be no need for additional washers or spacers.
Sly Fox
Sat Jan 31, 2015 7:57 pm » Post: #6 » Download Post
I'll get another photo.
Sly Fox
Sun Feb 01, 2015 7:06 am » Post: #7 » Download Post
Right side:
Left side:
That thingy, what does it do? The last time I saw torque arm was a crusty old Guzzi:
DUX
Banned
thingy
Sun Feb 01, 2015 10:20 am » Post: #8 » Download Post
I think the thingy is for the chain slider to hook onto and the other thing is the engine hanger alignment dufer.
For a more detailed and comprehensive explanation one will be forthcoming.
You have certainly set yourself a task in a short time frame, what you are aiming for would take me six months or more.
DUX. Smile
Sly Fox
Sun Feb 01, 2015 10:42 am » Post: #9 » Download Post
When I said 'thingy' I should have been more specific Laughing ..
The 'wotsit' for the engine….why do we need that???
I mean, I've worked on a lot of bikes and I've never seen a strap between the engine and the swinging arm before.
What could possibly be the issue Honda have found a solution for???
DUX
Banned
thingy
Sun Feb 01, 2015 11:46 am » Post: #10 » Download Post
As far as i know it is to do with the engine mounts being rubber sleeved, I haven't got to that bit yet but it is to adjust the tension it is the engine hanger alignment link, there is a bolt just next to the drive sprocket the engine alignment bolt that has to be at the correct torque loading of 5 to 6 kg-m.
I've not seen anything like it before either, I suppose the alternative method would have been rigid mounting and all the vibration would then be transmitted to the frame, so this device probably as it is described aligns the engine up so there is no bias to one side or the other and give the correct position for the drive sprocket to the rear sprocket, correct positioning would minimise vibration transmission also.
Whether you can ditch it without getting problems I don't know but Honda don't usually waste their time devising things if there is no need.
The other guy's will no doubt give you chapter a verse.
D. Smile
Sly Fox
Re: thingy
Sun Feb 01, 2015 12:23 pm » Post: #11 » Download Post
I think you have a good theory but I've just had a beer so I've dreamed up another:
The engine is aligned in the frame correctly by the steel sleeves inside the iso-rubbers.
The rubbers soak up vibration but they would allow the engine to twist slightly against the chain pull on hard acceleration.
So Honda have popped in a little strap that stops the motor twisting left or right.
Notice how the strap can move up and down but not left and right when tightened up.
Hey, it could just be beer talk. Laughing
Anyway, let's crawl back to the swinging arm spacer issue…
DUX
Banned
space
Sun Feb 01, 2015 12:35 pm » Post: #12 » Download Post
Yes that sounds like a good definition, the spacer issue I thought you had sorted that.
D. Very Happy
Sly Fox
Sun Feb 01, 2015 12:50 pm » Post: #13 » Download Post
Not yet DUX….
I've been looking at the parts scan closely and I think I have the correct number of parts the correct way around.
But for some reason there is about 4mm extra gap…..odd, one of the parts is wrong, (too short) or the previous nutter has filed one of them down.
DUX
Banned
spacer
Sun Feb 01, 2015 1:35 pm » Post: #14 » Download Post
That gap is for the brain cell. Laughing
It is very strange, why would anyone reduce the size, it does sound like you need a different spacer, was the s/arm intact when you got the bike or did you get a set of bits ? 4mm is quite a lot, I wonder if the centre bush/spindle is the correct length, p/n, 52101-kv3-831 distance collar, it doesn't give the measurement but one of the guys will know.
If it was all intact when you got the bike and was correct have you lost a spacer somewhere.
A bit of a puzzle.
Dux. : Confused
DUX
Banned
thingy
Sun Feb 01, 2015 2:04 pm » Post: #15 » Download Post
Sly Fox wrote:Not yet DUX….
Have you got the bushes in the thingy ( engine alignment wotsit) in correctly that would cause a problem if they are the wrong way round.
