Trying to set up my carbs with an HRC kit that came with the bike but can't figure out where the powerjets are I need to blank off! Have searched all over the forum and interweb and found them mentioned may times but no pics or specifics on where they are:-(
Any help would be appreciated:-)
Cheers _________________ "If your not first, your last!" Ricky Bobby
Anyway, not that any of that helps you much, Scott! LOL
The power jets are under the large alloy screws in the float chamber! Use a very close-fitting screwdriver to undo them, as they can be extremely tight, and are easily damaged.
Push the float pivot pin out, remove the floats, and you will see the large alloy screw. _________________ Andy.
