oil pump question mc21
peacey
Sat Jan 30, 2016 1:25 pm » Post: #1 » Download Post
On the parts diagram it shows the big rubber oring which goes at the neck of the pump, then below that is the metal washer which sits on the crankcase to stop the pump eating into the case, then it shows another rubber oring which sits right at the bottom of the pump. Just wanting to confirm that this is correct and that a metal washer and rubber oring are at the bottom of the oil pump?
Sun Jan 31, 2016 3:56 am » Post: #2 » Download Post
No, it's a poor illustration!
The second O-ring is for use with the later oil pump/cases, that have twin feeds. Look on the underside of your pump, and see if there is a secondary hole (about 2mm in size).
Late MC21s* and all MC28s have the second feed. MC16, MC18, and early MC21s have just the single feed (and therefore just the one large O-ring.
*It's not as simple as just a change of model year, so don't ask when they changed! Just look at the underside of your pump and the crankcase for two holes! Wink
Note: The MC28 parts manual illustration more accurately depicts the second O-ring.
cgallant
2001 Honda RS250
Sun Jan 31, 2016 1:23 pm » Post: #3 » Download Post
Also, an oil pump with the added oil feed needs to match up to a set of cases that have the required oil passage to the crank bearing.
If you put a newer pump on an older engine, you will end up with oil all down the engine and on your back tire (don't ask me how I know this).
Sun Jan 31, 2016 3:00 pm » Post: #4 » Download Post
You can use an "old" pump on "new" cases though. Just plug the extra hole in the cases.
peacey
Sun Jan 31, 2016 10:14 pm » Post: #5 » Download Post
Thanks for the replies. I took the pump off and guessed that it was for the secondary oil hole as I had a new o ring and compared, thankyou for the confirmation though much appreciated.
scb67
1981 Yamaha RD350LC
    Send private message View user's profile Yahoo Messenger
Sat Feb 06, 2016 7:04 pm » Post: #6 » Download Post
Andy wrote:You can use an "old" pump on "new" cases though. Just plug the extra hole in the cases.
Hi Andy, I just discovered the new crank cases I sourced for the rebuild are the later model with the additional oil inlet.....I did order a replacement oil pump....is there a benefit to using the new pump within the additional inlet?
"If your not first, your last!" Ricky Bobby
Sun Feb 07, 2016 3:24 pm » Post: #7 » Download Post
Yes. Additional lubrication to the RHS main bearing.
Ibgarrow
Enquiry about Peacey's SE
Sat May 21, 2016 10:15 am » Post: #8 » Download Post
Is this still for sale?
