Downshift issues
NSAAGGHHH
Downshift issues
Sun Sep 11, 2011 7:47 am » Post: #1 » Download Post
Gday guys, hope you can shed some light on another of my bikes strange personality traits,
its now decided it doesnt like downshifting into the lower gears when its warmed up to normal runnings temps. Its an intermittent issue but when it does shift its very smooth to the point untill the clutch is released you dont know if its changed or not.
When it doesnt shift, ive tried holding the clutch in again and very concientiosly pressing the gear shifter and it has no effect. Sometimes i can eventually get it to go, but its hit and miss.
I had the same reverse issue a while back with it not wanting to upshift under hard acceleration.
Ive changed the gearbox oil recently and the level is good (took 700ml) Upshifting no problems.
Side question, i need new exhaust gaskets - they are over $30 each here for genuine or ive seen an english auctioner selling some cheapies, for 3quid each or 10 for 12quid. Is a gasket a gasket? or is there somewhere else someone can share with me where to buy them?
nxrsr20
Sun Sep 11, 2011 9:34 am » Post: #2 » Download Post
I'd say your gearbox internals are out of spec, most likely due to a hard life. You may have to check them out.
NSAAGGHHH
Sun Sep 11, 2011 12:52 pm » Post: #3 » Download Post
Hard life sounds possible, how can i check it out? Ive never played with a gearbox
Sun Sep 11, 2011 4:33 pm » Post: #4 » Download Post
Is your clutch fully disengaging? If it's dragging slightly that'll make it hard to shift.
Sun Sep 11, 2011 4:43 pm » Post: #5 » Download Post
First things first I would check the gear change linkage and gear lever for play.
NSAAGGHHH
Mon Sep 12, 2011 12:13 am » Post: #6 » Download Post
Thanks for the response, I've ordered a new clutch cable to eliminate that but it does improve when I adjust it. Just doesn't stay fixed, maybe just a worn clutch cable?
Why would this only happen when the bike has been ridden for a few minutes and not from the start?
NSAAGGHHH
Mon Sep 12, 2011 12:15 am » Post: #7 » Download Post
Gear linkage - upshifting no play, downshifting there is a small amount of play. Can I adjust this out with the threaded gear selector rod?
Mon Sep 12, 2011 7:27 am » Post: #8 » Download Post
NSAAGGHHH wrote:Why would this only happen when the bike has been ridden for a few minutes and not from the start?
Because the clutch plates expand when they get hot, so if there's only a small amount of free play, the expanding parts take up the slack.
mighty max
Mon Sep 12, 2011 1:32 pm » Post: #9 » Download Post
Anyone have any issue with Tyga rear set?...Seem mine is hard to engage & dis engage gear...
NSAAGGHHH
Mon Sep 12, 2011 1:41 pm » Post: #10 » Download Post
so a new clutch cable should fix it, or the clutch is on its way out? either way sounds better thgan a stuffed gearbox Smile
Mon Sep 12, 2011 1:44 pm » Post: #11 » Download Post
Only if the old cable is stretched beyond limits - pretty unlikely really.
Did you use up all of the adjustment under the engine?
Mon Sep 12, 2011 9:16 pm » Post: #12 » Download Post
mighty max wrote:Anyone have any issue with Tyga rear set?...Seem mine is hard to engage & dis engage gear...
I wouldn't say "hard to engage & dis engage gear" but the stock gear lever definately helps.
mighty max
Mon Sep 12, 2011 10:47 pm » Post: #13 » Download Post
Just used back the whole stock or just used back the lever only?
NSAAGGHHH
Mon Sep 12, 2011 11:22 pm » Post: #14 » Download Post
Problem solved ( i think) the cable is stretched, ive adjusted it numerous times but always ends up with play. Ive had the cable too tight to the point its slipping when the lever is released then within a short time it can be loose enough its not disengaging when changing gears.
Still not sure why it only affcts the lower gears on downshifting only tho? Im guessing its because you can upshift without the clutch?
imdying
Tue Sep 13, 2011 12:55 am » Post: #15 » Download Post
It's impossible for a cable to stretch, it's steel.
It's conceivable the outer could get a little saggy and compress up, but the difference in the travel between a new and old outer over one metre should be negligible.
