Hi, my MC28 has a new battery (old one died of old age) and when I rode it on the track, I got one session in okay, second session it started but no headlight, then died.
So, in testing the charging system, I started with the stator. The battery is not getting a charge. Resistance across the windings is 0.6 ohm and open to earth - so all good so far. Starting the bike and at 5,000 rpm, one coil is outputting 50v AC and the other two are 36V AC - as a result I suspect the stator. Has anyone else come across this and managed a fix as opposed to a rewind of the stator or replacement with another one?
cheers
Simon
