MC28 cant start
mighty max
MC28 cant start
Mon Nov 05, 2012 3:42 am » Post: #1 » Download Post
Good day, can anyone know the knowledge regarding the CDI unit. Seem that the meter never stated any error code sign but the bike could not start. When swapping to stock CDI, bike easily can be started. Currently my CDI is P30. Could it burn out and can it be repair? Anyone have encounter before.
watfordhorn
1995 Honda NSR250 MC28
Mon Nov 05, 2012 6:53 am » Post: #2 » Download Post
Have you done the wire since to enable it to run the 030 card?
mighty max
Mon Nov 05, 2012 6:58 am » Post: #3 » Download Post
Yup i was running wire splice on the p030 and it is was running fine..after servicing and put all the pieces back..the would not start and the valve is not moving..the valve is not moving and there no indicate any error on the meter. I swop it into original CDI ( Luckly bought a new CDI for spare) and it work fibe and the bike can start. Thinking is it the CDI been toast?
cgallant
2001 Honda RS250
Mon Nov 05, 2012 1:33 pm » Post: #4 » Download Post
If the bike is running fine with a different PGM IV/Key card (stock) fine and the PGM IV/HRC 030 card (that are matched) isn't, then yes, I would think the PGM IV with the HRC card is bad.
When you put the card in, does the display show anything? or does it stay blank? Does the steering head lock, unlock?
There are a number of trouble shooting processes for checking/trouble shooting the PGM Unit, but hard to tell where to start without more details.
mighty max
Mon Nov 05, 2012 4:03 pm » Post: #5 » Download Post
cgallant wrote:If the bike is running fine with a different PGM IV/Key card (stock) fine and the PGM IV/HRC 030 card (that are matched) isn't, then yes, I would think the PGM IV with the HRC card is bad.
Display as normal p030... i saw joeking previous post had the same problem as me.
I have pm Moriwaki Man do no news yet.
mighty max
Mon Nov 05, 2012 4:05 pm » Post: #6 » Download Post
i was thinking to run Pgm 3 CDI on the MC28 OR 2 which is best for race use.
Tue Nov 06, 2012 7:20 pm » Post: #7 » Download Post
I virtually back to backed a PGM-IV with an HRC card and a PGM-II with a stripped down mc18 loom. As a bike to ride (on the track) you wouldn't know the difference.
The stator plug is different as is the carb solenoid plug. The wiring colours makes it clear what should go where.
PGM-II on an mc28 (note the smoke, just got it running)
You'll also need a set of clocks, a clock mount and somewhere to put the PGM-II.
As well as sorting out the ignition switch wiring/mech on a roadbike.
mighty max
Tue Nov 06, 2012 11:49 pm » Post: #8 » Download Post
Tks Fonty for sharing..
Im intend to race again but this my really 2 stroke race...
(my first 2 stroke cub race at carpark)..
