If you mean the pipes from the pump to the carbs then you can use any plastic or rubber type oil piping. I went for the clear type.
I often use my local bike spares shop http://www.ridersmotorcycles.co.uk/Scripts/default.asp.
The chap that runs it used to import NEW Jap bikes and has a wide knowledge of most things Jap 2 stroke.
Hope this helps.
Mike _________________ I don't mind dying...I just don't want to be there when it happens!
The magic word is bulk tube.
I think this is what you are looking for:
95005-3000150M
It's one meter and costs around 9 Euros. Inner diameter is 3 mm, outer around 6.5 mm (the correct clip is the B6.5 type).
You need two pieces, 140 and 160 mm.
Most of the air tube is 95005-5500120M (inner dia 5.3 mm) except for one 30 mm piece which should be from 95005-3500120M.
