I am interested in knowing the order of the frnt wheel spacers. According to CGallant, there are two, one longer than the other. (This bike arrived in boxes, so I don't have an example to look at)
As you sit on the bike, would the order be: Thick end of axel, shorter spacer, longer spacer, axel nut? Or are the shorter and longer pieces reversed?
I am definitely missing something because when I torque down the nut on the right side, the wheel still has too much side to side play - and my spacers are the same size. (Could be that the longer spacer I need is hidden in another box)
I also have another piece, a thin spacer with a lip on it, that looks like it goes on the axel somewhere, but I don't know where.
Curifor
