No spark generated, sometimes..
Enessr
Fri Apr 17, 2026 7:42 am » Post: #1 » Download Post
Right then,
I've still got this bloody problem with something
causing a no spark situation but only sometimes..
I rigged up a Sealy spark tester on the bottom
cilinder so when the bike finally does start, I see
a constant, very brite continuous flow of currant.
I've checked the pick-ups, both are within specs
Ohm wise.
Battery holds 12v and generator kicks out a constant 14.5 Volt.
Petrol is always present in the recently fitted see thru
filter.
Kick the engine over and most times I get sparks, then then engine cuts out
and no spark generated, even after10/15 kick-starts.
Could a faulty pgm ecu cause this?
I Hope not as that means another €7/800 as spares
in Italy are unobtainable and there's always a risk
that the used pgm bought from Japan is also faulty..
Any way to check the dam pgm ecu?
Zeus
Fri Apr 17, 2026 4:40 pm » Post: #2 » Download Post
It’s not a dodgy side stand switch is it?
Fri Apr 17, 2026 7:07 pm » Post: #3 » Download Post
Towards the bottom of the Workshop page on the main site, is a link to the Electrex Electrical Fault Finding Guide. Probably worth reading through it, as I know it has helped a number of people troubleshoot.
https://nsr-world.com/nsr250r-workshop/
Enessr
Sat Apr 18, 2026 11:46 am » Post: #4 » Download Post
Excellent Andy, thanks!
Enessr
Fri Apr 24, 2026 7:28 am » Post: #5 » Download Post
Right then, Quick update,
It seems that there's no spark being generated thru
the recently fitted Uotani sp 2 coil..
I'll swap the rgv's one over and see what the hell is going on.
Strange thing is that the cylinder was tepid so definitely firing.
Fri Apr 24, 2026 11:13 pm » Post: #6 » Download Post
Just out of curiosity, what's wrong with the OEM coils? They'll outperform 99% of tunes. They're capable of providing spark at 70+hp.
Enessr
Sat Apr 25, 2026 9:01 am » Post: #7 » Download Post
The Uotani coils were included in a box of spares Andy,
Just 'cos they look cool I suppose and generate a big fat spark.
No sidestand switch present zeus, eliminated a while back.
With the bike running if I remove the lt connector there's
no change in engine note, exhaust is cold as is gas exiting
the silencer which seems like a wiring problem and not the coil.
Atleast before the exhaust was luke warm, now not even that.
The only thing that springs to mind is that maybe, whilst
fitting the tyga carbon airbox, I may have stretched
or damaged the wiring loom trying to get the dam box in?
I 9nly hope it's not pgm related, I'm screwed then as
no parts available hear in Italy.
I'll go down later and check voltages at the LT coil plug, continuity test,
etc.
I'll swap the coil with the identical sp2 coil fitted on the rgv and see if it fires.
Forgot to mention that if I disconnect the running cylinder, the bike stops dead
And if I swap the LT plugs between upper and lower coils the bike
won't start.
