I can't get a spark on the top plug, the coil and plug are ok cos i swapped them with the front and got a spark there. i cleaned the terminals but no luck. i couldn't print off the wiring plan, is the members section up and running? i stuck a tester into the blue/black wire on the front and got a hell of a belt when i kicked it over but got nothing from either wire on the top coil. could the pgm be goosed? i hate electrics!!!
it's a name, not a condition
