We're still working on refining the electronics, but it worked for three laps then blew a fuse!
The plan is to make a box that will be isolated from the PGM2, 3 or 4, which will then bring the valves back from the dead. the plan is to measure rpm and throttle position and then open the valve a preset amount. I just tell him the numbers and give him the electronic headache
He says that once we've got it basically set to open at a set rpm blah blah blah, it'll then be quite easy to modify initial opening and fully open parameters either by rpm or throttle position.
I'll keep you informed
