Saved from the grave
rc46
Mon May 08, 2006 9:20 am » Post: #1 » Download Post
Just bought a NS400RF she's in a bit of a state and if i can get her running over the next few months. My long term project will be underway, Im gona try and get the motor into a NSR250 frame and make a 400 (maybe 500 big bore) road bike thats looks as close to the mc21 as possiable!!!
If any of you own a NS400 and are looking for bits ill be sticking parts up in classifieds as and when they become avaliable. I need all the running gear for now just to get it up and running first!
Oh well............here goes!!! Confused
Mon May 08, 2006 9:31 am » Post: #2 » Download Post
The NS400 lump in an NSR250 frame has been discussed here before, there's problems getting the rear facing cylinder round the shock as far as I recall, (I'll have a search).
Got it.......
http://www.nsr250.net/forums/viewtopic.php?t=2070
rc46
Mon May 08, 2006 10:05 am » Post: #3 » Download Post
Yup thats a fair point, Im gona try first and try and keep it as honda as possiable. I know it slides into a rgv frame or a rs250 frame nicely But i would like to keep it honda, First job is to get the we bugger running. its been sitting for 2 years. the good news is the battery took a charge last night and the ignition came on this morning, so ill clean all the bits out and see if i cant get her running soon, Ill need some advice on how to store an engine as i cant see this being a quick project and dont wana let anything go dry, but im looking forward to it, never done anything like this before!!!! I rekon that if i can get it into a good frame that will be the hardest bit of the project!!!! the rest is money Sad
maxim
Mon May 08, 2006 10:26 am » Post: #4 » Download Post
Good luck!! I think you'll be moving into the garage! Twisted Evil
j911brick
Mon May 08, 2006 3:12 pm » Post: #5 » Download Post
How about using a Hawk GT frame?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
nsr.wayne
Mon May 08, 2006 6:03 pm » Post: #6 » Download Post
If you read that topic that Fontyy put up and i think I've read somewere before that it fits in the NC30 frame as the shock is offset( but I might be talking crap),If you use a NC30 frame then you can use the NC30 swinging arm and build it to look like a MC28 Cool
rc46
Mon May 08, 2006 6:06 pm » Post: #7 » Download Post
MMM thats a not a bad idea, but not sure how it will line up, i know the rgv is a good fit so might have to go that route!
jeff350lc
Mon May 08, 2006 6:53 pm » Post: #8 » Download Post
If you go for the suzuki, give Mat Grant a PM. Hes got a NS/RGV Cool
Mon May 08, 2006 8:36 pm » Post: #9 » Download Post
I have been toying with the idea of doing this myself after I have finished my 21. I think it can be done with some serious re engineering of the frame, apart from getting the engine in and aligned I think one of the big problems is routing the rear exhaust as fonty said. the r/h upper shock mount is bang in the way and needs modifying in some way.I have seen a pic of an mc21 with an rg500 engine in it and it looks like the guy has cut away the top of the mount for clearance and welded a brace on to put the strength back, plus you will need to loose the sub frames r/h lower rail. the other problem could be clearance for the carbs between the fwd frame rails.
An rg500 motor in an rgv250 chassis is probably a more straight forward installation and you can buy all the parts from here www.suzuki-rg500.com .
Or a rd500 motor in areverse cylinder tzr chassis like this www.nkracing.co.uk
rc46
Mon May 08, 2006 9:33 pm » Post: #10 » Download Post
Problem with that is the engines are so GOD DAM expensive AND there is lots of them about (well when i say lots i mean more than any other conversion). I was gona do a RD350 job as its a twin and can go to 480 (i think) but when this came up it was just right, RGVMIKE had it on the classifieds and for 400 quid even if i find out the engines stuffed ill still make my money back in parts! Already sold the fairings for 85quid LOL Very Happy If i cant keep it NSR..... ill see if i can get a NC30 frame and try that, at least itll be honda!!!!!! vfr750 rear hub and away we go!!!! LOL fecking bikes Very Happy
