mc 18 clutch probem
tiago
mc 18 clutch probem
Sat Sep 08, 2007 11:42 pm » Post: #1 » Download Post
guys,my 18 wont go into neutral with the engine running but it would go into neutral with the engine off. how the i fix this. already changed the gear oil. clutch cable seems ok. Question
Re: mc 18 clutch probem
Sat Sep 08, 2007 11:56 pm » Post: #2 » Download Post
It probably isn't though. It sounds like clutch drag. Even if the cable appears OK, if it is worn and stretched, you may not be getting full movement.
It could be worn selector forks, but although they have been known to wear, it's not that common that they will cause neutral selection failure.
alannsr250
    Send private message View user's profile Send e-mail Visit poster's website MSN Messenger
Sun Sep 09, 2007 9:23 pm » Post: #3 » Download Post
Is it correctly adjusted though? I have had bike that had difficulty due with gear selection due to the clutch not being fully actuated when the lever is fully pulled in!
Is the gear lever loose at all or still as this can also contribute to neutral selection difficulty?
Honda nc23 CBR400 AERO 1986, 1990 honda NC23 Tri-Arm, 1987VFR400 NC24 Rothmans Rep, NSR250 MC16 1987, CL250s 1983. Moto guzzi zigolo 110cc 1958. Fantic 50cc 1972. Suzuki Cobra Race bike 500cc 2t 1975 , GP125 1975. Triumph T110 1954. BSA Thunderbird 1955. Ariel VB 600 1952, 1990 MuZ 125 etz.
tiago
Sun Sep 09, 2007 9:51 pm » Post: #4 » Download Post
thanks! il try to see if i can still adjust the clutch cable.
