Flywheel Removal...again...
bd197
1996 Honda NSR250 MC28
Sun Nov 02, 2008 1:53 pm » Post: #1 » Download Post
sorry...it's sunday, i had a late night and i'm not up top speed yet.
got myself a 21 flywheel for the 28. got myself a honda puller. can i get the retaining bolt loose? can i knackers!
crank keeps spinning...how do i stop it? bike is in gear and i've zip tied the front brake on...rear wheel still spins on the spot! yeah, both wheels are on the ground! Laughing
any tips people? thankyou!
Dave.
Sun Nov 02, 2008 2:03 pm » Post: #2 » Download Post
Bike in gear will never do it, even if you hold the clutch still it will just slip rather than undo the bolt.
A proper tool to hold the flywheel still is what you need, or (if you're a bit rough) an impact wrench, that'll just rattle it off.
bd197
Sun Nov 02, 2008 2:11 pm » Post: #3 » Download Post
cheers Fontyyy!
that's all i needed to know. best get myself shopping!
Dave.
Sun Nov 02, 2008 3:08 pm » Post: #4 » Download Post
The flywheel holder is obviously the way to go... rattle guns on anything connected to the crank aren't really a very good idea, and should only be considered if you are (a) absolutely desperate, and (b) taking the crank out to rebuild it! Smile
bd197
Sun Nov 02, 2008 4:50 pm » Post: #5 » Download Post
flywheel holder top of my shopping list. good job you people are here to look after me ! Laughing
invaluable as ever !
Dave.
Chester362
Sun Nov 02, 2008 11:19 pm » Post: #6 » Download Post
Best to get the flywheel holder if you can.
If you put it in gear you need to hold the rear brake on to stop the wheel turning. Sit on the bike with your foot on the brake. Get the socket and bar on the nut and apply pressure to take up the slack, then give a sharp pull to try and snap the bolt free. It will usually work this way. Sometimes the clutch will just slip, as Fontyyy says. Try backing off the clutch cable adjuster if it slips. Anti-clockwise to undo the flywheel bolt!
Kieran
Mon Nov 03, 2008 6:31 pm » Post: #7 » Download Post
Sometimes a little heat is needed. On my little brothers KX500, we found the bolt had been loctighted in Shocked with bearing strength loctight (you can tell by the colour- dad uses it a bit)
Application of gas torch, impact driver and hammer required Rolling Eyes
On the bright side, you didn't neet anything to stop it turning. The compression was sooo huge. (My older brother can't start it... too lightweight to push the kickstarter down Laughing )
The Chopster
bd197
Mon Nov 03, 2008 10:02 pm » Post: #8 » Download Post
brilliant ! cheers ! i've a flywheel holder on the way.
off topic...i remember tales from the crypt detailing the broken leg urban myth of a kx500 kickstart !! never dare go near one ever !
Dave. Laughing
