You gonna do anything about the crank??? i notice you don't have anything listed. That's prolly gonna be you weak link with the 300 kit. Especially if its an older high mileage mc 18 bottom end. _________________ MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
Well he can take it out and have it rebuilt now, or whoevers got the bike take it out and have it rebuilt if/when it goes, I know which I'd do. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
inbetween the gear selector and clutch leaver... there is a plug that goes into
the mc21 block that has sevral wires on it, removing it, you can see it has a o-ring on it, and at the end has small shaft with a key type thing at the end...
on new mc18 block, this plug has nowhere togo as it doesnt obviously fit this unit..
what is it.. do i need it?, engine runs without it...
Just join them using the wire splice guide but with out the sensor so it thinks it's in 3rd.
Only problem I can see it it will always think it's in gear and never show neutral.
