hi
can anyone give me some help with fitting my torque arm?
i have got the swing arm end of it on with the swing arm bolt back in but the end were it bolts into the engine is slightly out,enough so you cant fit the bolt.
i have loosened the engine bolts to try and get a bit of movement but cant quite get it.'
does anyone have some experience with doing this job and having a similar problem?is it anything to do with the castleted nut end of the swing arm bolt?
