Finally getting around to trying to get the speedo working on my MC16.
I have MC18 wheels installed as well as the right angle adaptor and left engine cover.
Does anyone have a picture of the interface used between the plastic coupler on the right angle drive and the output shaft from the transmission?
Does the shaft itself have a protrusion that mates to the coupler?
The parts diagram does not show anything obvious.
Thanks for any help.
forgive me if I've mis read/interrupted incorrectly your post
I've yet to put my MC18 back together but always assumed the plastic interface picked up its drive from the end of the shaft that the front sprocket is attached to and then transferred through the L shape coupling to the speedo cable
Jeff
As I couldn't figure out how to post a pic via a PM I've updated here as well
the speedo drive as measured on the flat surface is 7.8mm, I'm guessing you can work out the circumference as you can take that from the plastic coupling that goes over it
