MC18 Speedo
jeffco
MC18 Speedo
Wed Oct 06, 2021 1:51 pm » Post: #1 » Download Post
Finally getting around to trying to get the speedo working on my MC16.
I have MC18 wheels installed as well as the right angle adaptor and left engine cover.
Does anyone have a picture of the interface used between the plastic coupler on the right angle drive and the output shaft from the transmission?
Does the shaft itself have a protrusion that mates to the coupler?
The parts diagram does not show anything obvious.
Thanks for any help.
Wed Oct 06, 2021 4:48 pm » Post: #2 » Download Post
The MC16 output shaft doesn't have the same end as the later models, so can't drive the MC18/21 speedo.
It may be possible to make an adaptor to screw to the end of the shaft, or rebuild the transmission with a later shaft.
Wed Oct 06, 2021 5:09 pm » Post: #3 » Download Post
forgive me if I've mis read/interrupted incorrectly your post
I've yet to put my MC18 back together but always assumed the plastic interface picked up its drive from the end of the shaft that the front sprocket is attached to and then transferred through the L shape coupling to the speedo cable
019
134
A6A34BB3-EE78-453E-80A4-FB14C06EEAF3
Wed Oct 06, 2021 5:20 pm » Post: #4 » Download Post
in the time it took me to write the post above Andy had already answered Embarassed
Wed Oct 06, 2021 5:43 pm » Post: #5 » Download Post
All replies and interactions are welcomed, Nick! Thank you for adding the clear photos. Everything helps. Smile
jeffco
Wed Oct 06, 2021 7:13 pm » Post: #6 » Download Post
These pics are exactly what I was looking for. Back to the lathe. Thanks.
Tue Oct 12, 2021 10:03 am » Post: #7 » Download Post
Jeff
As I couldn't figure out how to post a pic via a PM I've updated here as well
the speedo drive as measured on the flat surface is 7.8mm, I'm guessing you can work out the circumference as you can take that from the plastic coupling that goes over it
let me know if you need anything else
all the best
