MC21 Rebuild
bluethermal
MC21 Rebuild
Fri Apr 22, 2022 8:19 am » Post: #1 » Download Post
Back in the day I was labelled ADHD, so will blame that on this fairly random sequenced thread. Idea
Here is the stator and flywheel condition on strip down
Fri Apr 22, 2022 4:29 pm » Post: #2 » Download Post
Where?!
bluethermal
Fri Apr 22, 2022 11:29 pm » Post: #3 » Download Post
Will put up photo when i can work out how to host photos on the web somewhere. Im better with a spanner than a computer Confused
Sat Apr 23, 2022 1:17 am » Post: #4 » Download Post
Feel free to e-mail them to me if you want, and I'll host them and add them to your posts. I already do it for a couple of members in a similar position. Wink
prelude2.2
Thu May 19, 2022 7:37 pm » Post: #5 » Download Post
thats a rough looking stator lol hows it going with it
bluethermal
Thu Jun 02, 2022 9:07 am » Post: #6 » Download Post
Hi Guys,
Here are hopefully all the parts needed to complete a full re build. The piston, rings and seals etc are from RGV Spares in Australia run by Dietmar Schulz, the other lot of parts are from Webike in Japan. Both these companies were excellent to deal with and can highly recommend them.
More to come...
prelude2.2
Thu Jun 02, 2022 9:23 am » Post: #7 » Download Post
looking forward to seeing it.
Thu Jun 02, 2022 10:09 pm » Post: #8 » Download Post
Sorry for the delay adding the photos... I got waylaid!
bluethermal
Mon Jun 06, 2022 7:44 am » Post: #9 » Download Post
Hey,
here are the flywheel and stator after abit of love...
bluethermal
Wed Jun 08, 2022 2:50 am » Post: #10 » Download Post
The barrels and heads and also condition of cylinder before going to be replated with Nikasil.
prelude2.2
Wed Jun 08, 2022 10:43 pm » Post: #11 » Download Post
looking like you're making good progress. cylinder doesn't look too bad either. where did you send it for the re nikasil?
bluethermal
Wed Jun 08, 2022 11:29 pm » Post: #12 » Download Post
Howdy,
NZ Cylinders in Ashburton NZ,
bluethermal
Tue Jun 28, 2022 9:17 am » Post: #13 » Download Post
Howdy
Removing cassette to replace output shaft seal and check condition of transmission. Never seen this type of trick build before, very cool. Replaced clutch and gear shift seals too. Had a few cracks at getting together again..
Tue Jun 28, 2022 5:31 pm » Post: #14 » Download Post
Be careful when you insert the cassette back into place.
There's a small spring that needs to be hooked back inside the cavity that can be easily overlooked, and get trapped between the crankcase and bearing holder. If you try and torque down the screws without hooking the spring into place, you'll crack the bearing holder.
bluethermal
Wed Jun 29, 2022 9:01 pm » Post: #15 » Download Post
Yes, saw the spring that could easily overlooked.
Is it possible to stretch the O ring that goes around the centre bearing on crankshaft to fit it? or does the crankshaft have to be dismantled?
Thanks
