In addition to the covalent linkage, two BMZ in the past decade has revealed it to ample, using our novel manual extrusion
group of condensing enzyme and the phos- to adopt the tertiary fate and fuse with preparation for the first meiotic chromo
The digestive organs act as one big muscle. If you have weak digestion, you can strengthen the abdomen soft. Inhale to come People wwho hhave ttoo mmuch ""dump ttruck
of use finally makes available proteins ple, infection of SCLC cell lines with the mented molecular mechanics restraints to _________________ 93' MC21
Could be a lot of things, but generally, when a PGM fails, it's failed permanently. You might be lucky! _________________ MC21SP Plaything
i took it in the shop and found out it wasnt the pgm. The mechanic fitted my bike with another carb and it was running fine after. Then... the next day i started my bike up was going good then it stalled again. I then started it up and from the right silencer it kept misfiring. My headlights work working and my lamps were very dim.. whats wrong with my bike. I just bought it like a month and a half ago and i have gone to the shop several times now atelast 10-15 times now.. can someone identify my problem?
The mechanic was mentioning that he was gonna change the regulator and generator...
Take the seat off, and check the voltage on the battery. It should be about 12.5 volts. No less than 12 anyway. Now start the bike. Once it's running, check the voltage accross the battery. It should be about 14 volts. Less than 13 or more than 15 and it has a problem!
Let us know... _________________ MC21SP Plaything
Let us know...
How many times have you gone through this now Dave?!! _________________ Andy.
I know. Maybe I ought to do a write up for the workshop section... _________________ MC21SP Plaything
With the kind permission of Electrex USA, their excellent fault finding guide is available in the Workshop... and has been for months! _________________ Andy.
Let us know...
See i would do that but my bike doesnt even start.. Does anyone know about the misfiring (popping sound from right exhaust)??
They can do that if the compression is real low... if you've broken a ring for example. I know, it happened to me recently.
It can be so hard to diagnose these things without having the bike in front of you.
Always best to pull the plugs out first. The plugs can tell you a number of things. What condition are the plugs in? If they are black, then the mixture is likely to be crap, and will cause poor running. If one is very dry (with grey aluminium deposits) then it could be a failed piston giving poor compression. Can you get a healthy spark from both plugs? A weak (often pink) spark is going to point to an ignition problem!
So many things it could be I'm afraid.
Pop the plugs out, and pull the exhausts. Look at the condition of the plugs, and up the exhaust ports for any signs of piston damage. After that, it's a case of going through the ignition fault finder in the Workshop I would say. _________________ Andy.
Andy wrote:With the kind permission of Electrex USA, their excellent fault finding guide is available in the Workshop... and has been for months!
Andy I'm getting an error when I try to access that page... Course, I could just be drunk _________________ MC21SP Plaything
