thermostat replacement help
panda_crx
Sat Apr 29, 2006 9:24 am » Post: #1 » Download Post
hey guys
i've got an MC21SE and it's started overheating. i can start it up to warm it up but it's fine but after less than a kilometre the temperature skyrockets
i'm new to bikes but i figured it's the thermostat seeing as i have plenty of coolant (unless anyone else has any suggestion?)
anyay after pulling the fairings, seat, tank etc i was a lil daunted at the location of what looks like the thermostat (up near top spark plug?)
what is the best way to tackle it?
from the top?
side?
i had a quick look from the top and it looks like gotta move/remove the wires in that box and the throttle cable?
any tips would be appreciated, pics would be even better.
also as far as i know there are no service manuals in english? i've looked online but havent found anything
thanks in advance
-Lozz
Sat Apr 29, 2006 12:11 pm » Post: #2 » Download Post
It is quite a git to get to, but is tucked into the top left corner where the down tubes meet the main chassis spars.
I think you need to remove the left hand fairing and coolant overflow tank to get to it, (not sure as I run total loss).
Are you going to fit a new one or simply remove it?
j911brick
Sat Apr 29, 2006 2:12 pm » Post: #3 » Download Post
Have you tried a new radiator cap?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
panda_crx
Sat Apr 29, 2006 3:25 pm » Post: #4 » Download Post
havent tried a new cap as i dont see why it would be that Question
there just seems to be no cooling when the engine is running so my guess was teh thermostat has died on me.
Wrench.
Sat Apr 29, 2006 3:34 pm » Post: #5 » Download Post
- remove all your lower cowl.
- put a drain pan under your lower head hose connection
- pull the lower head hose connection and let all the coolant drain
- disconnect the hose from upper-left of radiator
- remove coolant overflow bottle (2 bolts, 1 nut, 2 small hoses)
- remove your seat and gas tank
- remove upper head connection hose
- disconnect 2 wires from thermostat housing
- slide the entire thermostat assembly with hoses attached out of the engine area.
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
j911brick
Sat Apr 29, 2006 4:18 pm » Post: #6 » Download Post
panda_crx wrote:havent tried a new cap as i dont see why it would be that Question
I can't recall the exact science of it right now. It has something to maintaining proper pressure in the cooling system. The radiator cap is a fairly important componant of the modern pressurized cooling system. From what I've seen is the most common fault of overheating. Besides, its cheap and easy to replace. What do you have to loose?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
panda_crx
Sun Apr 30, 2006 1:52 am » Post: #7 » Download Post
Wrench. wrote:- remove all your lower cowl.
thanks mate, i've done most of that so far, just need to get the actual thermostat out, it doesn't help having big hands working in such a small space Mad
