newbie with a Q
Gravedigger
newbie with a Q
Sun Jun 11, 2006 7:42 am » Post: #1 » Download Post
Hi guy's for my first post I thought I'd ask a question , I have an MC18 (88 model) and at low revs it pops out of the left hand pipe, bottom cylinder and when the wires are disconnected it doesn't make a difference , it doesn't seem to be firing , when I take the plug out hte plug has weak spark and fires intermitantly.I've tried swapping plugs , coils , and checked the earth wires but it still does it , I can't find anything else that would cause it . Any idea's because I'm stumped .Oh forgot to add it's fine at high revs above 3000 rpm
Thanks in advance for your replies .
jeff350lc
Sun Jun 11, 2006 10:48 am » Post: #2 » Download Post
i think we've had this problem before, if i remember it was traced to the terminals on the wiring to the coils. Do a search of the forum ,i,m sure you'll find it.
Gravedigger
Sun Jun 11, 2006 11:22 am » Post: #3 » Download Post
Yeah I just finished a couple of hours searching and have come to the conclusion that it's either the carbs need cleaning , crank seal or a bad connection somewhere . When I find out I'll be sure to post it up as most of the threads I found never told of the result .
pbekkerh
Sun Jun 11, 2006 7:29 pm » Post: #4 » Download Post
No carb or seal can do that.
Loose connections in ignition circuit or bad battery/charging. The NSR is very sensible to battery voltage, maybe its just charging that little amount more, when above 3000rpm.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Gravedigger
Mon Jun 12, 2006 3:49 am » Post: #5 » Download Post
Ok I've cleaned the carbs , one of the idle jets ( i think ther'e call ) was clogged up . now it's better but still not right so tomorrow I'll change the plugs ( there due anyway ) and replace the battery and see what happens .
Gravedigger
Tue Jun 13, 2006 3:57 am » Post: #6 » Download Post
Ok I replaced the battery and plugs today now its running properly just needs tweaking to get it perfect , here's something strange it had NGK BR10 ECM plugs in it and apparently they are very hard to find as they aren't very common ?? and the mechanic I went to ( one I actually trust as he used to work on my RGV ) said to put BR9 ECM plugs in it because the 10's would make it hard to start and idle properly ?? strange but it's made a world of difference , maybe it's a climate thing Very Happy
