You shouldnt need to go that far, most of the time they press in with your finger. If you have one of those gay anodised ones maybe try taking some of the anodising off with some very fine wet and dry. _________________ If I have to take the carbs off once more...
They can't be that bad!?, Ive never seen any totaled ones, how did they fit in the old sprocket? _________________ If I have to take the carbs off once more...
So it would seem the lugs will be very tight to get into the Tallon sprocket. Most of mine are a perfect fit in the Rentals but some do need alittle help. So going off that they will take quite a bit of force to get them into the Tallons. do you have a vice at home, try pressing them in with that and a little clothe. _________________ If I have to take the carbs off once more...
You could do, but the next time you need a new sprocket they will wobble around like a loose wobbie thing. _________________ If I have to take the carbs off once more...
