rear sprocket lugs
fenton
1990 Honda NSR250 MC21
rear sprocket lugs
Sat Sep 16, 2006 7:48 pm » Post: #1 » Download Post
how do you put lugs back into a talon sprocket ? as the holes seem to small for them to press in
Sat Sep 16, 2006 8:30 pm » Post: #2 » Download Post
They should press in with alittle force.
fenton
Sat Sep 16, 2006 8:54 pm » Post: #3 » Download Post
ive tryed puting a bolt in with a socket to pull it up and it wont go do they sell new lugs as i dont see them in the parts manual
wb
Sat Sep 16, 2006 9:17 pm » Post: #4 » Download Post
Warm the sproket up a bit in the oven and then 'persuade' 'em in with a hammer or mallet. They are very tight, but that worked for me.
Luck
Wb
Sat Sep 16, 2006 9:53 pm » Post: #5 » Download Post
You shouldnt need to go that far, most of the time they press in with your finger. If you have one of those gay anodised ones maybe try taking some of the anodising off with some very fine wet and dry.
fenton
Sat Sep 16, 2006 10:19 pm » Post: #6 » Download Post
its a bit more than that its about 1/4 mill off i think the lugs are shaged
Sat Sep 16, 2006 10:22 pm » Post: #7 » Download Post
They can't be that bad!?, Ive never seen any totaled ones, how did they fit in the old sprocket?
fenton
Sat Sep 16, 2006 10:26 pm » Post: #8 » Download Post
it looks like when they have been pressed in last time someone used a hydraulic press and flat them off
Sat Sep 16, 2006 10:33 pm » Post: #9 » Download Post
Ive just been out side and had a measure up.
A Renthal one measures in at 14.10mm dia
A Tallon one 13.88mm dia
So it would seem the lugs will be very tight to get into the Tallon sprocket. Most of mine are a perfect fit in the Rentals but some do need alittle help. So going off that they will take quite a bit of force to get them into the Tallons. do you have a vice at home, try pressing them in with that and a little clothe.
fenton
Sat Sep 16, 2006 10:39 pm » Post: #10 » Download Post
tryed the vice trick but is still wont have it Evil or Very Mad is it worth turning the lugs down a bit
Sat Sep 16, 2006 11:06 pm » Post: #11 » Download Post
You could do, but the next time you need a new sprocket they will wobble around like a loose wobbie thing.
Steve C
Sat Sep 16, 2006 11:46 pm » Post: #12 » Download Post
Try warming up the sprocket in the oven and put the lugs in the freezer. Then get a BFH (Big F-----g Hammer) and go to work Very Happy
fenton
Sun Sep 17, 2006 10:52 am » Post: #13 » Download Post
job done!!!! i took them to my Ex workshop and skimed them on the lathe so they were a push fit
