2stroke oil lamp indication
demetris74
Tue Dec 05, 2006 2:57 pm » Post: #1 » Download Post
Guys
how can i be sure that the 2stroke low oil light is working? is it on switch on or when the bike starts that it lights up?
i turn the switch on and the light doesnt come on, at the moment i am not able to start the bike cause i wait for the parts to arrive.
James
Wed Dec 06, 2006 1:05 pm » Post: #2 » Download Post
The oil light should light up when the ignition key is first turned on with the kill switch in the run position. It will then go out after a few seconds. If it doesn't light up then either the bulb has gone or you have a short in the wiring.
demetris74
Wed Dec 06, 2006 1:14 pm » Post: #3 » Download Post
thanks a lot Stephen
Is there any common case to be the oil tank sensor?
James
Wed Dec 06, 2006 1:17 pm » Post: #4 » Download Post
If you jump the 2 wires (I think its 2) for the oil tank sensor the light should light up with the ignition on. This will test to see if its the sensor or blub/wiring at fault.
demetris74
Thu Dec 07, 2006 9:15 am » Post: #5 » Download Post
Found the problem
My MC21 has a PGMII wiring and it seems that the sensor red plug cables do not mutch. i removed the sensor and when i activate the sensor the 15amp fuse was burned then i checkd the diagram with the plug in i got this conlcusion, will fixi the correct order tonigh
James
