I get a call from Falicon today: they FINALLY have my crank done. Total cost $600+. For those that have not been following this, that is $600 to rebuild a NEW crank. So what did I get for $600? Improved oiling(?), dynamic balancing, welded pins, micro polish, truing, magnaflux, and hopefully some more stuff I'm clueless about. So now I have about $1,400 into this crank! _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
I would take some pictures if I were you so you can show people and tell them how trick it is, else you cant normally see it! Post them here too... _________________ NSRless again...
They had the crank for about two months (or more), but it probably only took a couple days to do the actual work. I suspect that most of what they did is not even visible. _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Yeah I know Matt, but I dont like resin and I dont want to get in there cutting bits out of such a nice set of cases. Maybe I need to build another motor. _________________ If I have to take the carbs off once more...
Well Steve, we can discuss it over juice, but I definitely think you need to build another motor. Can never have too many.
I do have to say though that peeking into F3 cases, with that rather cheeky F3 crank, is just bliss. Much more satisfying than looking at those normal, rusty old standard cranks. "Trick", just doesn't really do it justice.
You could use that bottom end as a handy doorstop and it'd still look fast
I'm guessing you really can't knife edge a two stroke crank. I know it does would well on four strokes though.
How much clearance do you need between the throws and the case? _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Knife edging an NSR crank would lose crank inertia, which might make it sound good on the stand, but it might make it slower down the chute. It would also increase case (free) volume, so would reduce pumping efficiency.
Some HRC kit cranks (RS250 for example) are made from tungsten and although they are smaller in diameter than the standard crank, they weight more and have a higher inertia. The smaller crank much be used with kit cases, which have a smaller crank case housing. All this help reduce case volume to hit the right ratio.
If the crank is well trued, and has the perfect balance factor, then you can run less than 1mm clearance without touching.
On RS125's in Japan we were skimming the OD of the crank and bushing the cases for less than 1mm clearance, with no touching.
The lighter crank went very well at short, point and squirt tracks, but a stock crank with bushed cases was the choice at the fast tracks.
Thanks Matt - that helps. I think the knife edging would hurt the pumping effeciancy and render the crank useless. What about polishing though? _________________ james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
