MC16 fork upgrade options
Canuck13
Thu Mar 22, 2007 2:26 am » Post: #1 » Download Post
Hi All,
I've a MC16 which will be back on the road shortly after a rebuild. I've also a MC21 rolling chassis from which I was planning to take the front end and replace the MC16 forks. Any idea how much of a hassle this is, is it worth it or are there better options?
cheers,
C13
Thu Mar 22, 2007 9:46 am » Post: #2 » Download Post
I think it took me nearly 20 minutes to do that conversion... I did stop for a cup of tea though! Smile
Thu Mar 22, 2007 2:59 pm » Post: #3 » Download Post
No Andy, it took you 20 minutes to do the conversation.....then probably delegated the job to Steve.
Thu Mar 22, 2007 4:10 pm » Post: #4 » Download Post
No Matt, it took nearly 20 minutes to do the conversion, and delegated Mr. Jason to "get the bloody kettle on... then you can hold the chassis while I do the easy bit!"!! Very Happy
Steve's not even seen the 16F3 yet... or the 18F3!
Thu Mar 22, 2007 4:25 pm » Post: #5 » Download Post
Ah, so Jason had the important job of making the tea.
I gather he'll be here soon, so I'll fill the kettle up. I'm a little lost as to driving it, so I'll leave that to the expert.
Thu Mar 22, 2007 6:22 pm » Post: #6 » Download Post
Andy hasn't seen some of the stuff I've got either lol Very Happy
Thu Mar 22, 2007 8:15 pm » Post: #7 » Download Post
Don't tell me you have found some more of that stuff Steve?!
Not something made in 1942 is it?! Wink
Canuck13
Thu Mar 22, 2007 9:33 pm » Post: #8 » Download Post
uhm.......so the conversion is worth it eh! Can I have a beer instead of tea tho or is that just not done Very Happy
I am assuming you switch to the MC21 front wheel as well, so do you keep the MC16 tire size or switch to the 21?
cheers,
C13
Thu Mar 22, 2007 10:34 pm » Post: #9 » Download Post
Swap the whole front-end.
Use the wider MC21 ( or an MC18/28 ) wheel, better disks, and 4-pot calipers.
You will need to carefully grind/file back the alloy lock stops on the MC16 frame as the stops on the MC21 triples are in a different location, and you end up with very limited lock.
The downside is if you grind them back too far the handlebars will interfere with the oil tank and trap your fingers, but as I have naturally dumped all that on the F3, it's of no consequence to me! Smile
Just take a little off the stops at a time until you are happy with the compromise between lock and functionality, then stop for a beer! Cool
Canuck13
Thu Mar 22, 2007 10:47 pm » Post: #10 » Download Post
Ok...thats no prob. So the tire size, stay with the original MC16 width/aspect ratio or change up to the MC21? Will this affect handling if I dont change the rear?
Thanks
Fri Mar 23, 2007 6:45 am » Post: #11 » Download Post
Well, you want to be slinging an R2J/R4J swingarm in it too, don't you?! Smile
That's a 45 minute job, and 2 cups of tea!
You can then use the MC18 18x4" or 18x4.5" wheel (140 or 150 section tyre) or an MC21 17x4.5", or if you are a little creative, RS wheels (up to 120/160).
You're going to want at least an MC18 R2J wheel anyway, else you will have odd wheels!
MC18, MC21, and MC28 all use a 110 front tyre, so running the MC18 R2J rear wheel with a 140 tyre shouldn't upset the handling too much.
jeff350lc
Fri Mar 23, 2007 8:31 am » Post: #12 » Download Post
One thing to remember is by using the MC21 front end and wheel you will loose your speedo drive. But this is a cheep price to pay for the improved front end. And as Andy says, put an MC18 in the rear too.
beakergixer750cc
Fri Mar 23, 2007 4:04 pm » Post: #13 » Download Post
can't you just transfer all needed 16 parts onto mc21 chassis? Wink
Canuck13
Sat Mar 24, 2007 5:37 am » Post: #14 » Download Post
K....good points. Now just gotta find a swing arm. As i said I have a MC21 rolling chassis but no plastic or tank or ...... would be easier maybe to look just finding a 18/21 lol Still not sure about the tea thing tho....maybe coffee
Cheers,
David
