Adjusting MC 18 RC valves
nickvr
Tue Mar 20, 2007 9:38 pm » Post: #1 » Download Post
Hi. Read all the articles i was able to find with TPS and Power / RC valves, All state the ignition & swicth method. When I manually turn values, and switch on, the both valves moves to right hand side of marks. Unplugging the TPS and switching back on, the valves / servo do not move a mm. Any ideas or how else can I set the valves without taking exhaust off?
Wed Mar 21, 2007 11:49 pm » Post: #2 » Download Post
With the ign off unplug the TPS and turn the servo by hand to full HI (the ign must be off!!).
Once the servo is set at high turn the ign on and the valve should sweep back down to the set postion (not full HI or full LO).
If nothing happens there is another way... but thats a later post.
NickoPen
Sun Mar 25, 2007 11:24 am » Post: #3 » Download Post
On the MC18 the method's different.
start the bike, valve moves to full closed at idle.
raise revs slowly, valve moves to full open somewhere around 3000 RPM (can't recall exactly)
raise revs a bit more and it goes back to full closed before starting to operate as designed.
On my bike, the "hi" and "lo" marks are dead on exact, or closer than any other mucking around has been able to get the settings.
Sun Mar 25, 2007 11:33 am » Post: #4 » Download Post
MC18 and '21 set ups are identical.
Both PGM-II and PGM-III sweep to full high at 3000rpm.
nickvr
Sun Mar 25, 2007 3:24 pm » Post: #5 » Download Post
Mine does that yes, with and without TPS connected. But from moves full HI to LO to full HI (inline with HI mark or servo) and it seems like that is not what I want i.e. full HI when setting to mark position?
Sun Mar 25, 2007 3:55 pm » Post: #6 » Download Post
The setting postion isn't at full Hi or full LO, its between the two.
nickvr
Sun Mar 25, 2007 4:18 pm » Post: #7 » Download Post
Thanks Stephan. Revving 2000rpm - 3000rpm causes servo to go to full HI. At that point both the valves are in line with the markings. Does this mean that my NSR's valves do not work they way they should (do not open fully at higher rpms e.g 10000 as they should then go past the markings thus open up more)??
Sun Mar 25, 2007 7:10 pm » Post: #8 » Download Post
Yes,
With the PV setting hole and pointer lined up the valve is still closed by almost 2mm.
If at full HI on your servo motor your power valve is only lined up with the markings then your valves are still not fully open. Full open positon is about 1.5mm passed the line/hole on the barrel.
This is why you disconnect the TPS turn the ign on and adjust the valve to the set postion. NOT blip the motor to 3k and then set the power valve up to the barrel markings. If you do do this then the servo will try and close the valve to far and good buy PGM.
nsr.wayne
Sun Mar 25, 2007 8:10 pm » Post: #9 » Download Post
nickvr wrote:Mine does that yes, with and without TPS connected. But from moves full HI to LO to full HI (inline with HI mark or servo) and it seems like that is not what I want i.e. full HI when setting to mark position?
Is your's a MK 1 18/pgm 1??
nickvr
Sun Mar 25, 2007 8:36 pm » Post: #10 » Download Post
I'm not sure if Mk 1.... All I do know is that with TPS connected / disconnected the PV does not move from LO position, only when revving between 2000 - 3000 rpms does it move to HI and past approx 3000 down to LO again. And I agree with Stephan that it most likely setup incorrectly as I can hear a buzzing sound from PV when ign and switch on, guess its trying to close an already closed valve!
nsr.wayne
Sun Mar 25, 2007 9:00 pm » Post: #11 » Download Post
The reason I asked was that my MK 1 mc18 does what yours does with the TPS disconnected "nothing" but my MK2 mc18 does what Stephen says when I disconnect the TPS.
nickvr
Sun Mar 25, 2007 9:02 pm » Post: #12 » Download Post
Thanks Wayne. I guess I have the MK 1 then.... Where does that leave me, how do I correct the valve setting now?
Sun Mar 25, 2007 9:32 pm » Post: #13 » Download Post
If it wont go to the set postion...
Start the engine, blip it to just over 3000 rpm and mark the servo motor where the pully wheel pointer goes too (it wont go as far as the HI mark on the servo body).
Stop the engine and turn the servo pully to this new mark. This is now full open.
Take the exhaust off and adjust teh cables so the power valve flaps are just recessed inside the roof of teh exhast port (0.2-0.3mm).
Button it all back up and away you go.
Do not use the marks on the barrels as these will now mean nothing. You are now setting it up, servo full open-valve full open.
nsr.wayne
Sun Mar 25, 2007 9:37 pm » Post: #14 » Download Post
Sorry mate I cant help you there as I was lost as well trying to set up my mk 1.I was following Stephens instructions as he told me them over the phone but unplugging the
TPS didnt do anything so I copied the setting from my mk 2 which is set up correct .
nickvr
Sun Mar 25, 2007 9:41 pm » Post: #15 » Download Post
Thanks, will try this. Just worried that I may damage the exhaust gaskets. Hard to get spares here for that model. Honda useally imports from Japan.
