Thermostat replacment
Page 1 of 3  Goto page 1, 2, 3  Next Download Topic
Jeff SZ
Tue Aug 28, 2007 8:57 pm » Post: #1 » Download Post
My bike never had one & I'm looking to install one because the mornings are getting chilly. Are there any cross overs from other Honda's that I can buy here in USA ? Or does some one have one I can purchase ?
Tue Aug 28, 2007 9:00 pm » Post: #2 » Download Post
Ive got a couple kicking around if you need one but to be honest I dont run one even in the '18 (which is what I use on the road) and have used it though a number of British winters without trouble.
Jeff SZ
Wed Aug 29, 2007 12:31 am » Post: #3 » Download Post
2 things I have found running with-out one.
Cold mornings temp never comes up to 60
In traffic temp rises fast
My other one doesn't have these issues with the thermostat.
Thanks much,
What do I need to send you for one ?
Wed Aug 29, 2007 6:57 am » Post: #4 » Download Post
I'll try and dig one out when I get home from work and PM you.
pbekkerh
Wed Aug 29, 2007 7:33 am » Post: #5 » Download Post
A thermostat will only make this worse, as any thermostat will decrease the opening somewhat, even at fully open.
It can only help raising the temp on cold days, by lowering the flow to the radiator, it can't increase the flow, over what is possible without it !
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
j911brick
Wed Aug 29, 2007 9:09 am » Post: #6 » Download Post
I think I have a new spare. I don't think there is a cross over. You can order a new one from Redline and have it in a week or so.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Chester362
Wed Aug 29, 2007 5:08 pm » Post: #7 » Download Post
Not always true. On some engines having a restriction can aid cooling by allowing more time for the coolant to absorb heat. Instead of rushing quickly past without taking the maximum amount of heat possible. Can supposedly maintain a more uniform temperature over the complete cylinder too.
On my MC21 race bike I just took the centre part of the thermostat out, leaving the original orifice as it was. I haven`t had any problems with the temperature yet. (Touch wood)!
apexxn
Wed Aug 29, 2007 6:13 pm » Post: #8 » Download Post
This is true. If the water is moving through the radiator quickly especially when the vehicle is stopped and the radiator isn't getting air, it takes longer for it to do it's job and cool down the water passing within it.
Wed Aug 29, 2007 6:28 pm » Post: #9 » Download Post
even with a thermostat mine both struggle to get warm on cold days and overheat in traffic.
60°c sounds OK, try racing at Mallory in weather that saw WSB abandoned 30 miles away, 50°c out of the hairpin, back in the 40's by the end of the straight....
Chester362
Wed Aug 29, 2007 6:32 pm » Post: #10 » Download Post
fontyyy wrote:even with a thermostat mine both struggle to get warm on cold days and overheat in traffic
Laughing Razz Laughing
pbekkerh
Wed Aug 29, 2007 7:09 pm » Post: #11 » Download Post
apexxn, Chester362
This is pure speculation. A restriction in flow will decrease effectiveness, meaning higher temp.
The thermostat increases temp by restricting flow. Now, at the same time, you say that restriction of flow too can decrease temp ??!!!
Poul
MC21SE, KISS box
Wed Aug 29, 2007 7:30 pm » Post: #12 » Download Post
I would agree with apexxn and Chester362
j911brick
Wed Aug 29, 2007 7:37 pm » Post: #13 » Download Post
Actually, your wrong pbekkerh. Not running a thermostat will cause uneven temps in the motor and depending on where the sensors are, it can cause the gauge to lead you to the false impression the motor running cooler, or hotter, than it really is. It can also play havoc with the fan. I would never reccomend running without the thermostat or restricter. I've seen some cars that have to use the full thermostat because without it the coolant would be directed the wrong way and the car would overheat (and the gauge wouldn't know it).
If you have a motor with a cooling problem, removing the t-stat won't fix the problem! It will only mask it temporarily. You need to fix the (real) problem.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
pbekkerh
Wed Aug 29, 2007 8:02 pm » Post: #14 » Download Post
j911brick: redirection of flow is not the function of a thermostat, its something extra build into it.
A thermostat controls temperature in an engine by restricting flow, giving lower cooling giving higher temp, OR increasing flow giving more cooling giving lower temp. Basta!
Thats all it does. When its fully opened, its function ceases. Then you can only get more cooling by removing it ( I talk only about the function a thermostat, if someone built a redirecting device or other into the thermostat is beside the point) as many thermostats decrease the diameter of the pipe where they sit.
Please don't just agree with the two guys, think and argue: how can the thermostat at the same time both decrease and increase cooling by the same mechanism: restriction of flow ??
I think we are moving dangerously close to the supernatural, but if anyone can finally expose the little devilish ghost in our bikes that burns out PGMs and reverses the physical laws in our cooling systems, I would be very happy.
Poul
MC21SE, KISS box
Wed Aug 29, 2007 8:07 pm » Post: #15 » Download Post
It can derease flow and increase cooling by allowing the water to sink more heat. Thats very simple. Slower flow, more heat sink, better cooling (up to a certain point).
