M16 coil off a MC21 or multimetre check?
Inthe80s
Sun Oct 07, 2007 4:58 pm » Post: #1 » Download Post
Can i stick my mc21 front coil on the mc16 to test the front cylinder for firing. as i thought a part from the different shape, isn't it just a coil after all?
i only want to run it a couple of miles to check a problems i'm having and want to eliminate the coil on the mc16, or failing this, i've just fixed my multimetre if anyone can describe how to check it for me.
thanks
richie
coil test
Sun Oct 07, 2007 5:11 pm » Post: #2 » Download Post
hi, here are the values for testing the coil using your multimeter.
Primary resistance - 0.1~0.3 Ohm
Secondary (no cap) - 2~4K Ohm
Secondary (cap) - 5~11K Ohm
cheers
richie
Inthe80s
Thanks richie
Mon Oct 08, 2007 7:32 pm » Post: #3 » Download Post
Once i hunt down the manual for the multimetre i'll give it a crack and post the results back on here.
Inthe80s
checked and here are the results
Sun Oct 21, 2007 10:45 am » Post: #4 » Download Post
hi richie,
re checking coil TEC Japan MP03 6Y17
checked the primary resistance which was 0.00 under range, this is same as the suspected working coil from the rear cylinder, in fact all readings were similar for both coils.
checked the secondary resistance which was 8.91 (cap) in range
checked the secondary resistance which was 4.29 (no cap) over range
checked cap 4.63
what do yo think?
