Can i stick my mc21 front coil on the mc16 to test the front cylinder for firing. as i thought a part from the different shape, isn't it just a coil after all?
i only want to run it a couple of miles to check a problems i'm having and want to eliminate the coil on the mc16, or failing this, i've just fixed my multimetre if anyone can describe how to check it for me.
checked the primary resistance which was 0.00 under range, this is same as the suspected working coil from the rear cylinder, in fact all readings were similar for both coils.
checked the secondary resistance which was 8.91 (cap) in range
checked the secondary resistance which was 4.29 (no cap) over range
