first ride home in the dark last week...hit the high beam a couple of times then i hit high beam again and pop i'm hurtling into an unknown right hander in complete darkness !!! BLOODY HELL !!! thank god when i flick back to low beam light is restored. underwear removed carefully when i arrived back home.
anyways...first bulb i check had blown it's high beam. so i just presume, yes it makes an ass of u and me, that's the problem. eventually sourced a new bulb, hurrah !
out again tonight, hits the high beam again, pop ! darkness is resumed. low beam saves the day !!! again...
home again and i check both bulbs...both have blown high beams. i'm guessing the previously unckecked bulb also had a blown high beam. am i right in thinking that if one high beam is blown then the other wont last much longer ? or are they completely independent and there is something more sinister to be found ??? it's just so bloomin' annoying !!!
thanks in advance,
Dave.
