JHA Slip Ons
mark h
JHA Slip Ons
Sun May 25, 2008 9:33 am » Post: #1 » Download Post
Folks,
Anyone out there have anything good or bad to say about JHA's slip on's, to oem chambers.
They're quite pricey, and I wonder if it's justified when I can get Swarbricks for half the price.
Does anyone recommend any others?
Airbox lid mod and rejet and that's it, so I keep telling myself.
geckoracing1
1996 Honda NSR250 MC28
JHA
Sun May 25, 2008 11:45 am » Post: #2 » Download Post
Hi Mark
I think JHA have stopped trading. They closed shop around 18 months ago, so you'll be looking at second hand cans nower days I think.
I use JHA on both my NSR and RS and have to say they are the best cans I've used, but as you say they are expensive. If it's for the road I'd use TYGA cans, they are excellent value and do everything the JHA do (except they are a bit heavier).
Dan
mark h
Sun May 25, 2008 6:09 pm » Post: #3 » Download Post
Do Tyga's cans fit both the oem chambers as well as their own chambers then?
banshee
1996 Honda NSR250MC28SE
Sun May 25, 2008 6:44 pm » Post: #4 » Download Post
yes they do fit on oem chambers as i have a set on my 28, though you do have to elongate the holes out...
mark h
Mon May 26, 2008 7:03 pm » Post: #5 » Download Post
Right then. If I fit end cans and do the mod to the airbox lid, I'll have to assume the standard jetting won't be right for this. From anyone's experience, what would I have to change in the carbs to make the most of these mod? Could it be simply a MJ change with needle repositioning or is it time to dig deep for a jet kit?
Mon May 26, 2008 7:51 pm » Post: #6 » Download Post
While you assume the jetting won't be correct... shall we assume you have an MC18?! Wink
mark h
Mon May 26, 2008 8:08 pm » Post: #7 » Download Post
Andy,
MC21. Wirespliced obviously. Full engine rebuild over winter after I got fed up with it dumping oil and fuel all over the place. Didn't rev out cleanly either. Now she's running much better, revs out cleanly.
Mon May 26, 2008 8:23 pm » Post: #8 » Download Post
Always helps to know exactly which model people are dealing with when asking technical stuff!
As for jetting advice, you will have no doubt read before in other posts, that every bike is different. I have known cases where MJ need to be smaller after a wiresplice, airbox mod and cans, and others where the jetting is increased! The only sure fire way of knowing is a plug chop, but for safety's sake, go up a couple of MJ sizes first and then work back down.
It is unusual to need to change the needle position with those limited modifications. You start to play with needle position when using the HRC emulsion tubes and air correctors, and open carbs, as these variables effect the mid-range transition a lot more.
