NSR250SE Performance air filter and reeds recommendations
GrantA
Tue Jul 15, 2008 7:44 pm » Post: #1 » Download Post
What recommendations do people have for performance air filter element (to fit airbox) and what racing reeds + stuffers and reed cages do people use?
Also where to buy from?
Cheers.
Tue Jul 15, 2008 7:54 pm » Post: #2 » Download Post
First one is easy enough -- HRC stuffers. Part number in the tuning section.
Air filter elements aren't so easy to come by. Daytona is probably the most popular/well known, but difficult to obtain outside of Japan. You would be better off buying a sheet (is that the correct word?!) of high-flow filter foam from someone like ITG or Pipercross and cutting it to suit. There is an HRC filter foam too, but I don't know the part number.
Never personally seen any proof that one set of reeds is any better than another (except old metal ones vs. fibre ones).
HRC stuffers (or inlet rectifiers to give them their correct name) should be available from Supporting Vendors such as TYGA Performance and Jap4Performance in the UK, and (good) Honda dealers. Supporting Vendors should offer Ti Members a small discount on those parts... let me know if they don't! Wink
apexxn
Tue Jul 15, 2008 10:17 pm » Post: #3 » Download Post
Here's a filter from a company called NTB. Can't tell you if it's any good or not as I haven't used it yet but figured I'd throw it out there.
It says high quality filter right on the package so it must be good. Laughing
andreb
Tue Jul 15, 2008 10:58 pm » Post: #4 » Download Post
UNI also makes a sheet of "universal" foam for elements. You cut to fit but its good stuff. I've used this a lot in custom air boxes and filter apps. I personally have Tyga stuffers with HRC reeds.
Andre E. Benguerel
1996 Honda NSR250R
2000 Honda RS250R (NX5)
2008 Honda RS250R (NXA)
AFM Expert #430
GrantA
Sat Jul 19, 2008 7:50 pm » Post: #5 » Download Post
Got all the parts sorted HRC reeds, stuffers and spacers. Also sourced myself a daytona performance air filter. Does anyone run these air filters? What are they like? Better than stock? Cheers for the info.
Sat Jul 19, 2008 9:08 pm » Post: #6 » Download Post
had a daytona in mine for ages and worked fine and just cleaned it with k&n filter cleaner every other month and came up like new Very Happy
