NF5 heads on a MC18?
hutch
Fri Jan 23, 2009 8:01 pm » Post: #1 » Download Post
Will NF5 heads fit the standard MC18 barrells and if they do is it really worth the expense and agro?
Fri Jan 23, 2009 8:26 pm » Post: #2 » Download Post
Have you seen NF5 heads?
hutch
Fri Jan 23, 2009 8:26 pm » Post: #3 » Download Post
Not close up, does that mean they are miles of then?
Fri Jan 23, 2009 8:32 pm » Post: #4 » Download Post
They are round for a start! Wink
hutch
Fri Jan 23, 2009 8:37 pm » Post: #5 » Download Post
Only got a rough phone camera pic sent to me , could have been triangular for all i could make out! I am a NSR noob though i my defence. I did read something about changing the heads so the plug was more central but couldn't remember what it was. Thanks for the advice as always
Fri Jan 23, 2009 8:56 pm » Post: #6 » Download Post
hutch wrote:
Only got a rough phone camera pic sent to me...
Don't get me started on the invention of Satan! Very Happy
MC18 heads are pretty good already... although you can use a rear on the front, just like with the MC21 and MC28, if you wish.
Fri Jan 23, 2009 9:02 pm » Post: #7 » Download Post
Not much wrong with MC18 heads as Andy says.
I had RS barrels and heads on one of my motors for a while. It was nice having the O rings but I wouldn't have them over a good set of NSR barrels.
Fri Jan 23, 2009 9:28 pm » Post: #8 » Download Post
There are a few things that, on paper, make the RS barrels and heads look way ahead of NSR ones including:
  • O-ring heads
  • True centre-mounted spark plugs
  • RC Valve design and adjustment
But when you can get the same power from NSR components it kind of makes it hard to justify the expense and hassle of fitting the RS parts. The NF5 RC Valve setup is a pain in the ass on an NSR as it needs all the actuation linkages and control cables for example, and the deck heights are wrong too, as the barrels are designed for the shorter single-ring HRC pistons (and usually AVGAS).
Waaaaaay better off modifying the NSR barrels and heads unless you have the time, knowledge, experience, and facilities to make use of the RS parts. Even then, NOTHING so far can reliably beat well modified original HRC spec 90~91 NSR250 barrels!
hutch
Fri Jan 23, 2009 9:28 pm » Post: #9 » Download Post
Ahh thats what it was. Rear on the front , luckily i have a spare set of 18 heads
Fri Jan 23, 2009 9:54 pm » Post: #10 » Download Post
I have to admit its cool having RS barrels though. They are after all from a GP bike!
shaned75
Mon Jan 26, 2009 5:07 am » Post: #11 » Download Post
how hard is it to fit rs barrals what are the differences
Mon Jan 26, 2009 7:28 am » Post: #12 » Download Post
The RS barrels themselves just bolt on.
Kieran
Mon Jan 26, 2009 9:07 am » Post: #13 » Download Post
its the deck height thats different. Hence the NF5 of NSR F3 crank and pistons.
How would NX5 pistons work? Whats the deck height bizzo there?
The Chopster
