nsr mc18 gearbox
HUNTN1
nsr mc18 gearbox
Mon Jun 29, 2009 5:50 pm » Post: #1 » Download Post
hi all,my mc18 all seems to be fine,with this new motor,but i have noticed the slow speed gear changes are abit cloncky/nocky,when i put it in first it seems to nock,and most slow speed gear changes 0-40mph are nocky,my old cbr400rr used to be the same and would get worse as the chain stretched,i am using a 10-40 semi putoline 4 stroke gearbox oil as that is what my local shop have suggested,,,,they said it would be fine and any fully synthetic would cause clutch slip,do i need a 2 stroke gearbox oil,or do you think its some thing else,the bike rides fine but i dont like this nock, the clutch leaver is adjusted so it has 1cm of free play,and this motor has a standerd wet clutch set up,i can get silkoline oil but am not sure what is the best one,,
NSR250 MC18
howl
Sun Aug 02, 2009 5:36 pm » Post: #2 » Download Post
Hi
I use silkoline light gear oil in 2 stroke gearboxes , not sure if it would make any diffrence though. Have you checked the front sprocket and as you mentioned the chain or rear sprocket ?
Al
Neal
Sun Aug 02, 2009 7:38 pm » Post: #3 » Download Post
I am happy with Bellray gearsaver 80w for 2t in my 21
