Wow, i would have returned the forks yo, its not exactly a cheap or simple operation
If im not mistaken the oil is only gonna affect travel speed. Soft or hard is ofcourse due to spring rate. So, if you want it to slow up, just tighten the lil screw a few notches.
i would have returned forks but when i stripped them there was 450ml of oil in 1 fork and 360ml in the other 1 so i cut my losses and will not deal with this mechanic again.
unfortunately i can only adjust preload with my forks not spring rate.
