fork oil replacement mc18
nsrjb
Tue Jan 04, 2011 7:38 pm » Post: #1 » Download Post
so i got my forks seals and oil replaced by a local garage.
when i got the bike back it was handling badly and the forks started leaking again.
i then decided to replace the seals myself.
i put 429ml of oil into each fork.
the oil used was a mixture of 10w 40 and 15w 40 to make 12.5w 40.
the seals no longer leak and the bike handles fine at speed, but around town at low speeds the front end feels very slippy.
any suggestions???
Kubira
Wed Jan 05, 2011 3:03 am » Post: #2 » Download Post
Wow, i would have returned the forks yo, its not exactly a cheap or simple operation
If im not mistaken the oil is only gonna affect travel speed. Soft or hard is ofcourse due to spring rate. So, if you want it to slow up, just tighten the lil screw a few notches.
Did you refit the shockie as per the nsr page? (( http://www.dreamgate.ne.jp/nsr/technical/mc28SE_forks.html ))
nsrjb
Wed Jan 05, 2011 11:04 am » Post: #3 » Download Post
i would have returned forks but when i stripped them there was 450ml of oil in 1 fork and 360ml in the other 1 so i cut my losses and will not deal with this mechanic again.
unfortunately i can only adjust preload with my forks not spring rate.
anonymous.shyster
Mon Jun 20, 2011 7:51 am » Post: #4 » Download Post
Hold on a sec, why on earth are you using a multi viscosity oil?
You should be using 10W, not 10W40.
